yeah, I might buy a pair and see how they fit to the car...wonder if you can replace the stock ones with them and open them up? Worth a look see, then get a body shop to fit them and extend a runner/lip to the length of the sill. I've mailed them, let's see if they reply...if they do I'll get a set and play. RK vents are painted and ready to go on
I’m looking forward to seeing how the RK vents fit as the inner skin would need some serious cutting for it to have an effect. The RK website doesn’t show it on their website.
rs.mark on instagram, I've already prepped the bonnet for fitting them. My view was every little helps with getting air from under the bonnet. The rear rubber trim is partially removed behind the engine also for this. Just deciding whether I want to retain the engine cover and have the naca duct (which hits the downpipe from position) fitted or not.
