250 Wheel Bolt Torque
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Evoluzione, Mar 5, 2015.
  1. Does anybody know the Torque setting for the wheel bolts on a 250 please?
  2. -Jamie-
    130nm
  3. Thanks
  4. Do people bother putting some form of copper grease / anti sneeze on the wheel bolts. I know torque load is generally dry, luring a bolt up can stretch it more.
  5. used to be 120nm, that proved insufficient when hot bolts came loose, Reno upped it to 130 couple years ago, I still find that lacking in really hot conditions and been going 140nm.
    avoid copper grease, Castrol Mollub Alloy the stuff to go for
    Danny Danger likes this.
  6. -Jamie-
    Studs are the way to go, I had the same problems with bolts loosing off at 130nm
    Changed to studs and no issues now. Torqued up after swapping wheels and the remain torqued all day.
  7. ^^^what he said^^^
  8. I think your right I've just stuck some oz racing wheels on and don't fancie them coming off.
    Is 68mm the right size for the stud conversion, running et45.
    Do you use red loctite or blue loctite.
    What do you do security wise so no scum bag can pinch them easy without having the locking wheel nut on
  9. Green 620 (62005 .5ml)
  10. -Jamie-
    Green 270 or 2700 as supplied with them by PMS.
  11. oh I know....Loctite all the wheel nuts
